Climate control
I was wondering if anybody has looked into swapping in an automatic climate control unit from either a Brittish or Australian 2. The actual panel interfaces look similar, but am curious about the potential wiring pitfalls and the lack of the recirc/outside air lever in the overseas versions.
I tried searching, but it basically returned every thread.
Welcome to the forum! I've never really thought of that actually. I really love the 2's heat/ac controls though. I like that they are direct linkages instead of using a vacuum or electrical system.
I do like the climate system the way they are now, but climate control is really the only luxury I kind of wish I had (my gf has it in her lexus...it spoils me). Plus, i like the simple layout of the australian/brittish versions.
I wasn't sure if this belonged in this forum (I thought of it as an accessory), or in the electronics/audio section.
Based one what I have seen in other models you need to get the whole heater/AC unit, control panel, wiring, control module, and a factory wiring book to get everything to work correctly. I do recommend getting one that matches your version ie RHD or LHD setup so the wiring is as close as you can get to start.
-Derrick
Hmm... sounds like you might be better off getting a Mazda3 with the option or waiting to see if it becomes available in the next version of the US 2. Unless you are a car wiring wizard? In which case, can we all bug you with our questions? :P
In Soviet Russia, climate controls you!
