Clicking sound on Driver's Window
dsm918
I get this clicking sound when lowering or raising the driver's side window. Sounds like the gear inside might be touching something on every rotation. I haven't taken it to the dealer yet since I don't wanna go through putting the stock intake back on. Will probably wait till I have something more serious that requires warranty work ;)
Anyone else have similar clicking noise on the driver's side window?
Thanks.
the window regulator uses wires on a roller to pull the window up and down, and usually makes a clicking noise when the wire inside starts binding or slip out of the grooves.
had the same problem in my 3. took it in and the dealer replaced the window motor. sounds like you need to take it in.....
