N7turbo
2023 CX-5 2.5T ... 2024 MX-5 RF GT
Due to the different locations:There are two different issues at play here. The one which was settled with the class action is for the valve stem seals (2.5T motors only) which caused loss of oil. There is another issue, cracked heads due to a casting defect, which is NOT covered under the class action (this occurs in both 2.5 NA and 2.5T motors). That issue is what leads to loss of coolant and engine failure. As far as I know, Mazda has never released a warranty extension for the cracked head issue- they just fix some under good will on a per case basis.
Cylinder head crack on NA engines causes an oil leak.
Cylinder head crack on turbo engines causes a coolant leak.
You're right that the valve stem seals on certain turbo engines caused oil consumption, but not a leak.
