ok, so ive searched hi and low for the answer to the question...does a check engine light make the car run in open loop? i cant seem to find the answer anywhere. I am trying to find out if the check engine light will affect my tuning. I have a small exhaust leak, doesnt cause any performance issues but im pretty sure its causing my check engine light. i need to have the wideband in the few part to get accurate readings and my lower o2 sensor for the car is behind the leak...yes i know i need to fix it at some point. so really what i want to know is does the cel make the car run in open loop therefore not allowing me to see any modifications to the map since from what i understand it runs in closed loop normally.
