Chassis engine bay fuel line p5 feed and return ?
03 protege5
Not sure which is which on the chassis engine bay fuel lines.. left fuel feed right return or oppisite?using high flow fuel rail with adjustable fpr as shown in pic
Thanks but not really i am using an hydramotorsport high flow with aeromotive fpr as shows in the pic i just want ot know. Which of the two hard lines from the under hood chassis lines are feed and return they are right next to each other
I have a gauge on there and its not showing any pressure i dont even hear the pump prime it worked fine before i started the turbo conversion i have on the 626 manifold so i have a few sensors i am not gonna use i also removed the emissions cansiter along with its sensors
Crank sensor needs to be plugged in for the pump to prime.. Just in case you have it unplugged.
Jumper the fuel pump relay socket and see if you can get it to run.
