Just finished changing all of the stock bulbs to LED. I got all the LED bulbs from ebay (different sellers). I think I ended up spending about $25 or so for the whole car.
The map, dome, and tailgate light use the same bulb. The courtesy door and license plate use the same bulb. The vanity uses its own bulb.
License stock and LED comparison:
License all LED:
Courtesy door stock:
Courtesy door LED:
Map stock and LED comparison:
Map all LED (but two different bulbs, left is whiter, right is bluer):
Vanity stock and LED comparison:
Dome stock and LED comparison (blurry):
Dome all LED:
Whole car including the tail gate light. As you can see, the courtesy door and map lights are bluer if you compare it to the dome lights. I like the bluish look because it makes it look more "high tech", but it's kinda hard on the eyes when you're trying to read something. So I switched the map lights.
I switched out to the whiter map LEDs (same as the dome lights):
The whiter dome lights match better with the vanity lights:
Map and dome lights match now. But the courtesy door light is still bluer. I may look for a whiter one later.
License all LED:
Courtesy door LED:
Dome all LED:
