It should already have a clear coat on it. The benefit would be that it's lighter than the stock hood.
about 70 lbs lighter. prob the best weight mod you can do along with a set of lightweight rims.
well the stock hood has been measured to be 72lbs. (with the ducting) So a 2lb hood is sweet!! haha, the fiber images i think is said to be 23lbs with ducting.
how 'bout that CF tailgate that i saw on SU site...what's the weight difference there?
Holy crap you MS3 guys have a heavy ass hood.
Probably some miss reading but the stock hood only weighs in at 39lbs with ducting and the CF is 18-20lbs with ducting.
Here is the direct quote
" Fiber Images Carbon Fiber Hood
Application: MAZDASPEED 3
Style: OEM Style
Stock Hood Weight: 39 lbs (including OEM air duct)
Carbon Fiber Hood Weight: 18-20 lbs (including OEM air duct)"
Just my $0.02, hoods are an important part of the crash crumple zone. Replacing the metal one with CF could turn the hood into a projectile when it shatters or at the very least, reduce the frontal impact energy absorbed by the car. Not worth the 20 ish pounds if you ask me.
where's the projectile going to go, through the windshield that is layered so that it doesn't shatter into a million pieces and go everywhere?
and there's plenty of more important crumple zone stuff in the frame
what if u rear end a truck and dont hit the frame?
or it comes in you lane and hits you head on!the frame will take come of it but most will be sheet metal.
the folding of the hood absorbs the energy from the hit. the carbon will probley just break and put for the force into the passenger compartment of the car and hurt the occupants. just a body mans point of veiw
