Cel code
Hey guys,
I been having this code come on lately P2187 PCM and U2064. I am running the pg intercooler and the forge bpv (blue with 2 shims).
I am located in Canada I heard the the colder the weather gets you have to install a stiffer spring. Is this true?
Thanks,
Derek
its telling you that you're running lean. what other mods do you have? have you upgraded your fuel pump cause it might be crapping out. the u2064 one means nothing other than "there's something else wrong with your car"
Hey I'm getting a cel as well, it's a egr below threshold code, it that common? Where is the egr solenoid on this car? Its a intermittent cel light, if I do a lot of expressway driving it will turn off, until I drive in the city and then it will turn back on. I'm guessing because egr isn't being used above a curtain speed but anyways what do you guys recommend?
hmm got this same code the other day. and about 2 weeks ago i got a code for running to rich. all kinds of wierd. have been having issues though my last 3 fill ups. usually run down to under 1/4 tank and then fill since i do alot of driving and id be at the gas station every 2 days if i did 1/2 tank. anywho, after filling, i start the car and it bogs down, like its starving for fuel. so i ease into throttle a bit just to get it going. ive been thinking fuel pump but not sure. fuel pressure ranges are fine, avg 420-435 on idle, 1600-1800 on WOT. Any ideas?
