Catalytic converter after exhaust manifold
2 bolts on air baffle, 3 bolts on heat shield. gets u access to 4 nuts on upper part of cat. jack car. 2 bolts on j-pipe heat shield. 3-4 bolts on bottom of cat ( working from memory) 2 bolts j pipe support to engine. 2 spring bolts jpipe to rest of exhaust. gaskets u can replace. 2 doughnut , and the cat needs metal gaskets top, and maybe bottom.
What are these doughnut gaskets you mention? Is the metal gasket on top of the converter the same as an "exhaust flange gasket" which you can buy in advance autoparts or autozone?
