Car Problem! Help please. (mazda mp3)
Keatonc
2001 Mazda Protege MP3
So I decided to go to the main mazdaspeed forum for this. I recently did an engine swap since my previous engine died. It was the same engine of course (FS 2.0L 16DOHC). When I finally bolted and plugged everything back together, I put the battery in, and hooked it up. As soon as the battery is hooked up, ALL of the electronics activate. Since the horn is loud and annoying, I pulled the fuse for that just so I could see if the engine would start. But there is no turnover or any noise. Please help me out!
When you unhook the battery when you hook it back up you got to play with the lock and unlock buttons on the key fob to deactivate the alarm. There should also be a button under the dash somewhere to do it with to.
activate alarm. deactivate. open door. close door. repeat. then start car. use key fob or use key on driver door lock.
Also, the windshield wipers go off, and the windows go up. Its not the alarm system that did that.
