njintau_fsd
- 2003 Mazdaspeed Protege
Hi all:
I have a 03 Spicy MSP and recently I replaced the turbo mani with a steedspeed and did an oil change. So today, while I was on the highway, the car just stopped responding and the wideband showed it lean out to around 21.1 which is as high as it will go. I managed to pull over to the side of the road and tried starting it but it wouldn't start, all it did was turn over. Here are the weird parts here:
1) While I was slowing down, even though the speedo and tach were at zero, I could still hear the engine run plus I still had power steering.
2) Even after 2 1/2 hours, the temp gauge is still stuck at hot, I blasted the heater to see if the air was still coming out hot and it wasn't.
3) I checked for any blown pipes or any other vacuum leak sources and so far the only thing I could find was the metal pipe going from the exhaust mani to the EGR was loose at the EGR but it was still threaded on.
4) Thinking it might have been a blown head gasket, I checked the oil dipstick if there was any coolant and checked for steam or any slimy residue. All checked out fine.
5)The car had a CEL for a few days even though there was no code ( the Autozone reader couldn't complete the connection to the ECU.)
What do you guys think is the problem? Blown head gasket? Electrical problem maybe? Could the temp sensor connector have shorted some how causing the ECU to cut the fuel as a fail safe? Could the ECU be at fault?
