Hello all,
The issue I am having is a tricky one because there are no signs of the problem until the car is driven for about 30 minutes. Also, there is no check engine light so with a mix of the two, every mechanic I take my car to is stumped.
To clearly describe the issue, after I drive my car for about 30 minutes it starts to hesitate, stumble, sputter and bog/decelerate when I try to accelerate. I have no vac leak, the plugs, wires and coil packs have been recently replaced and I just had the timing belt replaced. My car has 175,000 KMs on it. I drive this car like an old lady so it can't be due to abuse. Has anyone ever experienced this or can anyone suggest what it may be?
Edit: I should also add that I can accelerate very slowly if I give maybe an 1/8th throttle and build boost slowly or if I play with the clutch and gas pedal to increase revs. When in neutral I can rev the car but it sputters.
