so my belt was squealing a lot today from running through all the snow so i went to check the tension and noticed that the belt is riding on the very edge of the pulleys. the belt is still completely on the pulley but not sitting exactly where it needs to be. i went to loosen the tension and was able to turn the bolt out plenty far, but the slider is seized up or something. do i have to loosen the bolt on the slider too or is it probably just frozen from a little rust and the cold? i tried some liquid wrench and heat but it hasnt moved at all yet.
