can not start overhouled engine...no OBD codes....
lzsmt3
hello everyone, i buy a damaged car...this come with water into engine, the head blocks, gaskets, spark plugs, and all necessary for this kind of major work was replaced....the problem is that the engine don't start...I'm trying to find the root cause, I need your help to see if something is missing during the inspections and analysis to solve it.
Model: 626, 2001, 6 cil. 2.5, 24 valves
components new: camshaft sensor, gaskets, filters (oil,gas, air), oil, sparkplugs, sp cables, ignition module, valves, 24 valve gaskets, belts
repaired components: head blocks (machine shop), the car can not start, i have spark in ea plug and gasoline pressure and electrical signal for every injector....
notes: the principal pulley was accidentally bent in one of dents (used to be detected by crankshaft sensor), the dent its aligned with the rest of dents...but with a less width detection area that the others dents...
I'll appreciatte your help.
Regards,
LZSMT3
