can i 235/35/19
check out the first few pages of the show off your ms6 section and there is a sweet cherry with 19's i think his fenders are rolled tho.
i think they are 8" wide 48 offset
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/45-18 3.8in 12.8in 25.6in 80.5in 787 0.0%
235/35-19 3.2in 12.7in 25.5in 80.0in 792 -0.6%
you may get a bit of rubbing. if you roll the fenders you should be fine though.
the kid that has the wheels had them on a acura tsx
and he does not know the offset
they only come in 32 and 48 witch is better
my car is stock ride hight
48 is better, but you probably will still need to roll your fenders. its not too tough, just make sure you heat up the area first.
