Can Any One Answer This Question Please!!!
WALTERLONG
1985 RX-7 LOVING IT
My Mazda failed emisions test they said it was to much gass escaping through the tail pip.What could I do top fix it my car doesn't smoke
Add some Beano or Mallox to the gas tank. That should eliminate the excess gas and make your car feel better.
The test results printout will show you what portion of the test failed (was outside the acceptable range). Just take it to a dealer. They'll know which part of the emmisions system will resolve the problem.
You might also want to take it to a different testing center if possible. Occasionally they'll be different, which used to happen a lot in AZ and retesting somewhere else was the first thing you tried as a fix.
