So lately, I've been getting some weird "pop" sounds coming from the front (seems like more on the left side) of my car. They're very quick and don't happen all the time, but it seems to be more frequent at lower speeds. Also, when I am accelearting, as soon as I let off the gas, my RPMs will drop down to like 1300 or so and then quickly bounce back up to about 1800-2000. This happens very quickly, almost as if some kind of resistance is keeping the car from rolling forward.
These conditions lead me to believe that my CV joint is bad. The passenger one was replaced (not by me) a year and a half ago, but the driver's side one is original. My question is, is it possible for the CV joint to go bad with the boot still intact? And if so, how hard is it to replace this axle assembly?
The only thing that's got me worried is the dynamic damper - is this easy to remove from the old axle and install on the new one?
P.S. - I should mention that there is really no other possible source for a front end pop like the one I'm having - control arms, tie rod ends, wheel bearings, swaybar links, and struts/strut mounts have all been replaced in the last 10k miles.
