Camber setting 07 MS3
Captain GJ
2010 370z / 2006 MS6
Just got my car lowered and was wondering what the camber settings should be for the front/rear? Thanks for any help. Drop was 1.1". Posting pics as soon as wheels are on.
I have a 05 2.3L Sedan and the Camber for the rear is right around -1.3 degrees... I would assume that the speed should be close to that. Your front should still be good from what I have been hearing...
Im not lowered, but I got the camber kit too... The adjustable ones. I got enough weight in the trunk that I was sitting at a -2.1 on one and -2.2 on the other... Now I am at -1.7 so I can clear the rear fenders...
Captain GJ said:
Yeah, the rear is actually at about -2 right now, so I went ahead and got the camber kit.
Which camber kit,the MS3 or an adjustable one like SPC ?
Id like to know a little more about that kit. Is that a setup for both front and rear? Has anyone installed this yet?
Im wondering the same thing,after speaking briefly with a suspension shop they thought there was already a little bit of adjustment left in the rear camber bolt,but thought the front had no camber adjustment.
Mind you he has never worked on a mazda3 before.
Im tired of procrastinating so ive gone ahead and ordered this kit to suit.
I have the SPC kit.... I think it is great. You don't really need the camber kit unless your looking at changing the camber for racing or something... But the rear is a def if you have a ton of audio (Like me) or if your lowered...
