cam and valve question
CF_KoiFry
2003 Protege5
So...for turbo I notice a lot of guys run corksport cams
Well I found a set, intake and exhaust.
I'm building an engine and looking at the supertech +1mm intake valves.
Would it be detrimental to run the oversized intake valve with both cams?
Should I use oe valves with both cams?
Can I run both cams AND the +1mm valves
Or should I just see about the exhaust cam and run the +1 valves?
do both. no question about detrimental.. only detrimental to the pocketbook if you know what I mean :P
honestly you don't NEED the +1mm, you just need a really good valve job done by someone who knows heads. do a competition 3-angle job on em and you wont be disappointed $$
