Hey guys,
Who Am I:
For those that don't know me, I'm Ice (Kris) I used to own a Blue BJ SP20 (Protege5). Im a bit of a NA nut, the challenge of getting power NA is what drives me. I'm well aware that boost is cheaper but a good engine shouldn't need copious amounts of boost to make power. An efficient engine is a good engine.
Unfortunately I had my first accident at fault and the Blue SP20 came to an end. I toyed with swapping my engine into a MX5 but the amount of custom fabrication, and potential changes to my circumstances in the future meant that a two seater with a small boot would simply not be big enough. Further, the amount of fabrication meant that it may not get finished, a risk I wasn't willing to take.
The reason that this car is called Caboose 3.0 is that prior to this I had a blue 1.8 protege which got written off when someone ran up the back of me. The second blue protege (the SP20 referred to above), I wrote off
While this car isn't Blue it has enough of the old car going into it that I conceded that it would be ok to call it 3.0.
Scope:
Build 2.0 is going to be a continuation of 1.0, I will endeavour to document more of this build. However I am quite busy and forget at times to update forums.
Aim is to reach 190whp on pump fuel. The excellent news is that down the road I now have a station that has Flex Fuel (e70-e85) and a little further away a station that sells race fuel. So that should be a nice little surprise to see how much I make on e85. Anyone wanna take a guess?
Only other consideration for the build is that it needs to last a while, I won't say uber reliable. But I don't want the engine turning into a tear down and rebuild every year. I don't have the coin nor the inclination to repeat all this work. If this engine blows up then another build will occur, on another platform.
Otherwise, if you have any questions regarding my build or theory regarding why I did something ask away
Hopefully you learn something along the way as well.
Who Am I:
Scope:
