If you have your VICS valves locked in the open or closed position, you will lose power on either the low or the high end, depending on the position. I wouldn't mess with that, unless you have a device that allows you to pick the switchover rpm. Then you might be able to get a couple more HP for a couple hundred rpms.
If you have VTCS closed you will just lose power overall i think. It looks like you lost power overall which makes me think you are messing with VTCS, but that dyno sheet is hard for me to read. VTCS are the valves that are right before the injectors.
People remove the VTCS valves completely becuase even when they are open their profile can impede the flow somewhat. This in conjunction with a porting job should give you a better topend.
