Hey All!
Just picked up a MP3 a few weeks ago and the sway bar bushings needs to be replaced. I understand that the front is 25mm and the rear is 20mm. I also will be replacing the end links, just to be on the safe side.
The biggest question is, are there greasable bushings out there or just stuck with the standard stuff?
Also, I want to replace the bushings for the engine and transmission mounts because there is some pretty crazy movement going on. Do I have to replace the entire mount or just the bushings? If just the bushings, can some one point me to some ones that are better than stock?
Thanks!
Thanks!
