One way to tell if your valve seals are leaking, after letting the car sit over night, remove the spark plugs and look down the holes to see if any wettness to the piston. If you don't see anything( valve seals are not leaking), put the spark plugs back and start the car for maybe 2 secs and remove the plugs again. If you see wettness and don't smell gas down the holes, it's the piston rings that are bad.
