built 3071r big turbo build up
i may order some falken azenis rs615 tires in the coming days, although i don't need them for some time. I'd like to get into the 11's, but I dont know if that'll happen.
lol yea i know its missing thats obvious lol. my question was more in the direction of asking why it missing haha.
I think that was my fault for the missing screw during the first install of the big turbo. Sorry jon, =(
no big its all sealed up fine. I need a good wire brush and a tap and die to retrace the threads. the car is very very comfortable behind the wheel now.
13psi pull 3rd through 6th = 0.0 knock the whole time according to dashhawk, AFR's right on, and EGTs are proper. This is all on the stock intercooler still.
I'll fix the DP when the car is cold and in surgery for the coils and rear sway bar.
how many miles are on it and where are you shifting at?
i've got over 500 miles on the car now, and i'm driving it :D
The engine builder - john day - had already (through machining) taken care of the peaks and valley's in the cylinder walls and told me to drive the car like I would if it had 10k miles on it once it was in the car. I didn't do that though, just because of the spec stage 3 clutch.
I've been shifting at 6500rpm or 6800rpm. Dashhawk came in today (rerouted from oklahoma to texas) so i'm able to do logs on my own unit within the coming days. Hopefully I'll get the boost dialed in where I want it to be shortly.
PM sent.
^ yeah how is the driviablity with that? How stiff is your clutch pedal? I couldnt find the pressure plate force listed.
The clutch
^ yeah how is the driveablity with that? How stiff is your clutch pedal? I couldnt find the pressure plate force listed.
Yes please. I imagine you will get used to it pretty quick. Is it more street or track? I would think more than a couple of folks are getting to thinking about a clutch upgrade. Let us know what you think, when you get a chance.
Im curious because my buddy just upgrade his clutch and plate in his S2000 and he loves how it grabs but says stop and go traffic is murder on his leg lol. I drove it and it did take alot more force than it did before. It didnt bother me much but i could see it getting old if you live somewhere with a billion stop lights like i do.
