hey everyone, i just need some input from thoes of you ppl who have built up ur speed or kno about building it up. right now i have ingen cai, perrin fmic and corksport exhaust. what i want to end up with after im done is about 300 whp. obvuiusly im gonna get a built motor( havnt decided between ********** or mam), new injectors, mpi tuner, clutch(thinking the spec stage 2++), a GT28RS turbo. im plannng on thios order: motor, clutch, and turbo all at the same time(only running about 7 lbs of boost), then the mpi and injectors not too long after. and run the higher boost after i get the engine management. is there anything else i need or should do b4 i start running boost enough to hit 300 whp? thanks for the info.
