dusterbd13
- 03 P5
so while changing out a bad headlight bulb, I discovered that the wire bail that holds the low beam bulb in on the passengers side is no longer retained in the housing. the housing has cracked at the casted in spot, allowing the bulb to flop around.
so, if an attempted repair doesn't work tonight, iv have to replace the housing. which is stupid expensive.
the sedan headlights, however, are ridiculously cheap on ebay. how does the light output compare between the two? if the P5 has better lighting, ill spend the good money. if not, ill convert. im all but night blind, so I have to have good lights.
thanks
Michael
thanks
Michael
