robp5t said:Could detonation be so light my nock sensor would have not picked it up this is not factory nock sensor. By the way turbine is fine not one single nick nothing. Tops of other pistons all have a slight carbon build up no white spots.
shane02pro5 said:Curious as to what knock sensor you are running and with what Engine management. Nevermind I see you also have a Haltech but does it have input for a knock sensor.
I have J&S and am now worried!!!
robp5t said:No the Haltech does not have a place for a knock sensor. I am using the knock kit from Holley which on the dyno we did show some knock but the tunner did pull some timming and was working fine for the last 5000 miles. So I dont know if it was the broken spark plug or not or if it was bad tunning.
I am waiting for new pistons from Wiesco they said they had to make them up and would get them out to me ASAP also have just ordered the J&S knock gauge kit it will probably work better than the one I have know.
Earful said:CP make their pistons for the FS-DE motor?
