broke the timing belt
323b6t
i broke the crap outta my timing belt on the 88 gt
anyone know where i can get some info on timing spec and cam setting?
need to know ASAP
its my dd
Sorry I am a week late.
Easy to setup. The crank gear had a "u" shaped groove on it. Line it up with the "v" on the oil pump. It will be straight up. The cams are really easy too. Line up the I on the intake camshaft with the "v" on the cam gear metal backing plate, it will be straight up. Line up the E on the exhaust camshaft with the "v" on the cam gear metal backing plate, it will be straight up.
Stock timing it 10-12 degrees if I remember correctly.
Derrick
