Ok I installed new CV axles in Sept its october now an the drivers side axle broke off at where the circlip is and the axle slipped out . any ideas is that just a bad axle that faild? Or was the axle itsself not the correct on (looks like the correct length and fittment was correct.
anyway I pulled out that axle and will need to source a new one, the bad news I retrived the circlip but the little dime sized broken off part fell into the trand ...how do you get it out? there doesnt seem to be a trtrans pan in this 1996 protege dx
http://www.vindecoder.net/?vin=jm1bb141xt0333936&submit=Decode
VIN: JM1BB141XT0333936
WMI / VDS / VIS:JM1 / BB141X / T0333936
Model: Protege
Type: Car
Make: Mazda
Model year: 1996
Manufacturer: Mazda Motor Corporation
Manufactured in: Japan (Asia)
Plant: Hiroshima, Japan
Sequential number: 333936
Get Full VIN Check Pro Report or Get Vehicle Records & Owner Info or Get Certified Vehicle History Report
Body style: SEDAN 4-DR
Brake - front: Disc
Brake - rear: Drum
Brake system: Non-ABS
Consumption in the city: 27 miles/gallon / 8.7 liters/100 km
Consumption on the highway: 35 miles/gallon / 6.7 liters/100 km
Curb weight: 2385 lbs / 1084.1 kg
Doors: 4
Driveline: FWD
Engine series: 4-Cyl. 1.5L
Engine type: 1.5L L4 DOHC 16V
Fuel tank: 14.50 gallon / 54.9 liter
Fuel type: Gasoline
Overall height: 55.90 in / 142.0 cm
Overall length: 174.80 in / 444.0 cm
Overall width: 67.30 in / 170.9 cm
Safety restraints: Driver and passenger front airbags, active belts
Standard seating: 5
Steering Type: R&P
Tires: 175/70R13
Trim level: DX
Wheelbase: 102.60 in / 260.6 cm
For more information visit:Get Full VIN Check Pro Report
Get Complete VIN Audit
Model: Protege
Type: Car
Make: Mazda
Model year: 1996
Brake - front: Disc
Brake - rear: Drum
Doors: 4
Driveline: FWD
Fuel type: Gasoline
Standard seating: 5
Steering Type: R&P
Tires: 175/70R13
Trim level: DX
