Brake Warning Light ON~ Please Help!
zoomzoom870
2004 Mazda 3 s
One day, out of the blue, my dash board ((Brake)) warning light came on. No ABS light. I went and got my brake pads(professionally) changed and back rotors. I got my front rotors turned. E-brake is not up. Brake fluid is full. Is there anything else that could be the problem? Is there a way to reset this light?
The light does not require re-setting. I would remove the fluid level sensor terminals
and check that all the wiring is good and that the contacts in the reservoir are good.
Look for corroded connectors and frayed wiring.
Clifton
I still need help!
