brake swap
You need a full right up. Its not a simple 1 2 3 step process. You can check out Club Protege, as they might have useful info for you.
It can be much simpler than that, although, not necessarily as cheap. Use the following OEM parts in replace of the original. This applies to the BG.
Spindle, Hub
R B461-26-111B
L B461-26-115B
Rotor, Brake
R/L BB4C-26-251C
Caliper, Brake
R BRY6-26-98ZR
L BRY6-26-99ZR
Shield, Splash
90-91 R/L BR74-26-261A
92-95 R/L B613-26-261A
Hose, Brake
R/L B461-43-980C
The hub assy is the same for both disc and drum brakes.
I did it on an 88 626 and just swapped the whole knuckle assemblies. But not with new stuff. Didn't have to change the combo valve thing either, worked great.
