The reason that they were probably very tight is because under the caliper slides(metal where the tip of the pads go) rust builds up after a while. And because the rust takes up that space when you put the pad in its very tight. What you did was prob not a good idea, but if its a little snug or loose like you say and you feel no driveability issues i say you should be fine.
