Brake noise... all the time
2True
2003.5 P5
The noise is starting to get to me, thought I could just ignore it but I figured maybe someone here may have some input. Anywayz, at low speeds (5-20mph) there is a squeeking coming from my front right. It's pretty loud and emarassing on a new car.
I have checked ALL the pads and they look good, only 14K on those puppies.
I have checked the rotor for any signs of corrosion or starnge wear, all good.
I even took it to the dealer and they cannot "re-create the problem" which means they don't want to deal with it I assume.
I even went and got some brake cleaner but that didn't help.
The squeel does incrase if I am light on the brakes which is why I figured it was the pad.
This typically happens when it's cold outside, which is always, in Alaska.
Anyone got any ideas on what I should/could look for?
It's not a big deal, just extremely annoying. (argh)
its like a squeak from the tire/axle right?!?! i have that like that too i went to the dealer and they said oh ur brakes are fine, as soon as i come home it starts again arrgh!
its VERY annoying i know.. i still couldnt find a cure to that so im with u on this one..
in alask ehhh? you local or AF/Army? Check sig. this is outside of Anchorage.
The only thing i ever got with my brakes is after a rain or wash they rust/dust up and a slight grinding can be heard until the breaks wear it away! some pads just squeak and need to be replaced!
