Brake Fluid Change Frequency
Does anyone have a dealer that recommends changing brake fluid every 16,000km, or 12,000 miles?
Was at my dealer this week and got pointed out a maintenance schedule that had brake fluid change at 16,000km. Other info indicates Mazda does not have a recommended brake fluid change in North America, just Europe.
I believe this to be the most bogus schedule ever produced- and this, after my 40 years working in maintenance, especially considering I live in an area that has average humidity of 25% or less.
Most other brands indicate 30,000 or 3-4 years c/o. My dealer is a stealership, and I took this up with the sales staff who agreed the number is inappropriate. What are your dealers recommending? Thanks
Specifically, vague. For Canada it shows every 4th service. The CX50 Hybrid has a nominal engine oil/filter interval of 16,000 km. Toyota drivetrain, so that fits with Toyota practices. I service at 12,000 km because I like that interval based on the weather and my driving habits. The dealer wants 8,000 km intervals. No.
So at that rate, following the manual of every 4th service interval, depending on which km is chosen it could be 32,000; 48,000; or 64,000 km.
Hence my question to determine if any other dealers than mine are attempting to steal unnecessary service $$$$ from unsuspecting customers.
If you just go into the dealership with the assumption that they will literally tell you ANYTHING in order to get your money, it makes it easy to ignore these ridiculous suggestions.
Get a tester and check it every now and then. Are you at 3% or more moisture? Then you know it's time to change. If not, then you are good. Take the guess work right out of it.
This is all about chemistry. Brake fluid is a glycol-based fluid, just like antifreeze. Glycols gradually absorb water over time and then break down into acids that corrode the brake system (or cooling system). Change every three years at the same time that you have your radiator serviced. That simple.
If you NEVER change the fluid eventually you might have rust in the brake lines and cylinders, but it takes years for that to happen. I've heard it's best to change it every two years, but I think your local climate has some influence on how fast brake fluid degrades.
better braking ?any troubles with abs afterwards?
Fluid degrades remarkably quickly, at least where I am at.. Less fade and generally better brake feel. Never have I had an issue with ABS afterwards on either cars or motorcycles. Additives in the brake fluid also degrade over time. Add particulate contamination as well.
I live where the summers are humid. Never have I changed brake fluid. I am not sure how much fluid may have been flushed during a brake job, as I pay to have that done. Not saying my method is correct, just saying I have never had any noticeable issues.
Have always done it on a 2yr schedule, 3yr at the outside. I suppose I could stretch it beyond, but with as much as I drive it's one of those things I'd prefer to keep on top of. It is the braking system, after all. IMO, not worth fooling around with.
For my 2016.5 CX-5, in the owners manual the maintenance Schedule 1 (under "Mexico") lists brake fluid as something to replace at the 2yr or 25Kmi mark.
This springtime, it'll be time to do a flush/bleed again. Standard maintenance, generally accepted maintenance interval.
Question about brake fluid brands. Each manufacturer may have their own fluid package, that exceeds dot3 standards. Mazda has their own branded brake fluid which they recommend. But being Mazda branded, it is also expensive. I plan to use Prestone dot3 brake fluid. Do you guys get the Mazda brand, or some other brand? Has anyone used Prestone? I was reading that some people used a pen tester on brand new bottles and it tested positive for water. But it is most likely the pen not compatible, since there is no water in a brand new bottle of any brake fluid.
