- 2001 Mazda MP3
So, the fact that people are using a second port injection fuel system to tune a DI car is kinda annoying me.
What i want to do, is scrap the DI motor all together, and use a base model 2.3 with a custom kit.
I want the engine bay as clean as possible, if it doesn't make the car go, stop, or turn, i want it out. When the hood is open all i want to see are fenders and motor.(show quality stuff)
Issues that i can think of with possible solutions:
ABS is controlled by the stock ECU. Can i possibly disconnect the abs and it funstion ok? or should i look for a BBK that is for something without abs and just run manual brakes?
Gauges. I Know this car lives and dies by the ECU and the gauges(stories from people who swapped LED's in their gauge cluster and fried their cluster and had to get a who new one programmed by mazda.) SOOO manual gauges no biggie. Oil pressure, RPM, wide band, water temp etc etc.
what about speedo. its driven by the abs sensors on our car, and i've mentioned going away with ABS all together if need be.
Options
1. buy a 2.3 mazda 3 as CHEAP as i can find for a donor car. Use its ECU and gauge cluster and run a haltech to control everything so it will basically be a built mazda 3 in a speed3 shell.
2. take everything out of the engine bay, all sensor guages etc etc. fill shave the firewall. Get a motor built with custom turbo kit. take it to a race shop(have one in mind) and haveit tuned with with a holley standalone. sacrifice AC but have a totally smooth and clean engine bay(but what would i do about Power steering) i'm not willing to sacrifice PS.
This would be a show car/ hopefully car magazine cover car.
thoughts ideas suggestions.
Options
