I posted this in another thread, I think it'll be valid here also...
Correct me if i'm wrong, but from what i've been looking at is that the MS3 has both a MAF and MAP, so running hybrid, VTA, or Recirc the ECM should be able to compensate. With that said, the system and how it works as I understand it. Air enters the intake track past the MAF on it's way to the turbos' inlet. The air then is compressed inside the turbo and heated, then sent to into the hot side of the intercooler. The air then travels threw the intercooler reducing it temperature. Then the air travels threw the cold pipe into the engines' throttle body. As the throttle blades open and the exhaust gases increase the turbo's impeller speed creating more pressure between the hot pipe off the turbo outlet and the throttle body. When the throttle closes the pressure in the cold pipe rises. Having no place to go the pressure pushes on the diaphragm of the BPV. The BPV opens slightly allowing the extra pressure of from the cold pipe to "vent" into a separate track leading back to the turbos' inlet AFTER the MAF. The way I see it is, that since there's only one MAF in the system, the computer can't tell how much air has been lost or gained after the BPV opens. Having a MAP in the system will. The MAP is able too look at the drop in pressure and balance the A/F ratio to keep the engine running. The way I see it is the ECM is already set to adjust the A/F ratio when it sees these drops in pressure within its allowed safety parameters. The ECM work with injector pulse width and IAC positions to keep the engine from starving for fuel and air. With an aftermarket BOV or Hybrid valve, you are able to adjust the tension on the spring. This spring pressure allows the piston or diaphragm to open at a certain amount. I would assume along as you have the right tension on the piston or diaphragm this will allow the ECM to keep the engine running without being too rich or too lean no matter how much or how little air goes back into the intake. As long as all the air between the hot pipe and cold pipe isn't depleted and the ECM can adjust within it's allowance everything should run as it was stock. An example of this would be having a BOV set too loose causing almost all of the air in the intercooler track to be depleted causing the ECM to adjust 100% rich, which would cause backfiring and stalling. Again, if i'm wrong please correct me.
Rob
