MIA protege said:yes its true our low compression helps boost more. valve job ??? u have an automatic ?
MIA protege said:going manual i think ... we will see ... im going to be seeing someone tomorrow about it. maybe he knows something better to do to my auto tranny
TampaSport20 said:Huh ??? We have the same compression as 2.0L's....9:1....
He asked with lower compression pistons could we run higher than 20 psi ?? I imagine you mean on otherwise stock internals ??? Possibly..that might be pushing it on stock rods,then again with GOOD tuning, maybe so......
peepsalot said:You guys run MAPs instead of MAFs?
shaneMazda2000P said:if i am not mistaken , hiboost runs a map 2 bar map sensor..
Witchdoktor said:at the moment I'm running 5psi non-intercooled. it's a 2nd generation mitsubishi eclipse turbo custom welded by WagnerMotorSports. I bought the kit used which ran me 2200 including installation. fuel management is vortec 12:1. I've had the kit for almost a year and a half now. I had an oil leak coming from the oil pan the week after install which was a 400 dollar fix. Then about 6 months later the turbocharger itslef blew. I got a replacement off ebay with 7k miles for 150 bucks. no problems since. FMIC is due in july so I plan to up the boost (10ish). After that I'll put it on the dyno. The kit ran 165whp w/IC (not fmic) at 6psi off the protege it came off so we shall see.
THEGOLDPRO said:also i chose this intercooler because of how simple it was to run piping, if you get a traditional intercooler with the piping on either side of the intercooler then you will have to run the piping weird, and have more of it, i have very little piping with the setup i got, there for less lag.
also i have no idea what size piping you guys run, but i run 2 inch, and it is far better then the 2.5 inch i ran, when i ran 2.5 inch i had lag upto 3.5-4k, no i reach boost at like 2k, no lag what so ever.
THEGOLDPRO said:it has less lag because its a small motor,with a small turbo, so if you go too big of a pipe it wont flow as good.i only speak from experiance, my old setup was 2.5 inch with a traditional type intercooler, and it felt bad, no power belew like 3.5-4k, then all of a suddin boom power, with the new setup, and smaller piping i reach full boost much lower.
