Boost spike
oskinosmee
07 mazdaspeed 3
I did the mbc and bck and im wondering what makes it spike so high, And drop so low.
Is it the mbc?
or stock bypass valve?
huh ?
are you talking about the TurboSmart BOV ???
If you bought a MBC (Manual Boost Controller) and your asking this question, please go and take it off right now.
describe what is happening exactly. what gear whay rpm wot or partial. under wot I get no spiking at all with my turbosmart mbc. stock it spiked to 19 and held 13 at 5500 now it hits 18 and holds 17ish at 5500. keep in mind that partial throttle boost will change. also you can't be flooring it in 6th at 2000 rpm cause the turbo will spool to fast and you will lean out. if your floored in 4 through 6 just keep it above 4000 rpm to be safe
