does the cs intake have an air straightener? if not that could be the culprit since the MAF cant get a good reading. get a DH or something to log the engine while its doing this. itll help eliminate the guesswork and narrow down the possible causes
But either way couldn't it be because of the sensor reading the extra air in?? And since theres no tune to compensate for the extra airflow the ecu is trying to compensate for it on its own and its not being able to??
that would result in running lean/rich not related to boost. honestly, unless someone has had the same issue and resolved it none of us can help since we have nothing to go on. OP datalog the event and post it up. 4 psi sways in boost is not normal .5psi...ok. could be something as simple as a loose connection....
and hitting 15psi below 3k in 6th is a good way to throw a rod.....
Here's another option. Restore the intake to normal temporarily. Put the stock air box and inlet pipe back on and reset the ECU. Drive it a bit. If you are still getting the boost swings, then you know you have a leak in the plumbing somewhere, either a boost tube, a vacuum line or a problem with the boost control solenoid.
I gather you are not throwing any check engine light codes.
Did you properly install your boost gauge? Was it working fine before the intake mod, or did you install it at the same time? Maybe you do not have it connected properly, or there is a leak in the line to it?
Since the SRI and TIP are your only mods, you should be able to return everything to normal and take it to the dealer and get it diagnoses and fixed under warranty if it still does the same thing.
I dont think the OP needs a tune after just the CS full intake. I have more mods than him and my car runs perfect with no boost surging in any gears. This is definately some sort of vac issue or maybe a sensor issue.
+1 for putting it back to stock to see if it does it anymore. Not that hard and will help in further troubleshooting.
Wait so ur running catless with no tune....so you've probably got a cel on ur dash on almost all the time. I hope you have a dh or scan tool since you will have no idea if anthings going wrong until its too late. The ecu can only compensate to a point....
I'm old school on tuning. I have an installed mechanical boost gauge. I do check AFR's and check and clear CEL codes with an professional grade OBDII scan/reader that is not a Dash Hawk. Only CEL's have been from the O2 sensor, and that has since been eliminated by the "diode fix" since the raised O2 bung and even a spark plug fouler extension did not stop the CEL's, which would come and go.
Stock tune is amazingly flexible on these cars as long as you don't try to bypass the boost cut and fuel cut safety features or raise boost above stock levels. If I decide to go in that direction, AP custom tune would be added.
This i good to know. I going to try my luck and install the DP when it comes and see how everything turns out. I do have a WB02 coming also so i could monitor my AFR's. Eventually Im going with the standback and full controll flash but i dont have the 1300$ to drop on it yet, until then ill hope for the best
WB02? Why not just get a dashhawk? Car comes with a WBO2 anyways.
I dint know or cars came factory with a WB02 sensor, My fault for not researching it. would of saved me some $$ if knew this cause i could have just ordered the guage and not the guage sensor combo.
I plan on getting a dash hawk in a month or so but, I have the tripple vent pod and i wanted to utilize it. the only thing in there is my boost guage and it looks crappy missing the other 2 guages.
