Boost Gauge Install Question
SpeedThree2K7
2007 Speed 3 Sunlight Silver
I will be installing my Prosport Premium Boost Gauge on my '07 MS3 soon. I would like it to be white during the day and amber at night. does anyone know the proper wires to tap into for this install? Thanks in advance.
since nobody has helped you yet i will, if you post the instructions for me to read.
Also, are you putting this by the steering wheel or on the center dash?-
you can tape the orange wire in the (DSC) switch. Mine is done so when I turn the light on, the gauge lights up.
Thanks, I got my info elsewhere. I was mostly curious of where to find the wires in my Speed3 that I need to tap into. Thanks though! I appreciate someone finally replying!
i had a wire diagram i wrote down for the car, the wires, colors with descriptions, ill look for it and post if i find...i have aftermarket radio so tapping into the wires was alot easier
Using Add a circuits
I used "cigar" for power (red wire),
"IG SIG" for White Illumination (white wire)
"Tail L" for Amber Illumination when the I turn the lights on. (green or orange wire? I can't remember)
