Bolt pattern on 2016 CX-5 GT?
bbtfastback
2016 CX-5 GT Tech
Can you guys confirm that the bolt pattern is 5x114.3 on the 2016 cx5 GT ?
Buying rims in Ontario from Costco and the 2016 cx5 isn't listed just 2013-15.
Without knowing rim width and offset, there's no way to know. Did you look it up by vehicle application on the Costco site?
It looks like they'll fit if you trust the internet. The Costco PDF recommends: X47567 or X99715N.
Googling those part numbers shows these specs:
Diameter = 17"
width = 7"
bolt pattern = 5x114.3mm
center bore = 71.5mm
offset = +40mm​
Mazda 17" OEM wheel specs:
Diameter = 17"
width = 7"
center bore = 67.1mm
offset = +50mm​
Diameter = 17"
width = 7"
offset = +40mm​
Diameter = 17"
width = 7"
offset = +50mm​
Thank you!!
The center bore is bigger, not sure if you ca add centering ring to a steel wheel though.
