Bogging and smoke?????
so i just added oil to my ms6 for the second time since ive owned the car. it has about 43k miles and i have owned it for about 2 months. i use mobile 1 5w20 motor oil. the car sat for the past few weeks due to training im in and then last night i started it up drove around with no issues. Then today i drove to wal mart and baught oil. again no issues on my way to wal mart. added 2 quarts of oil and then left the parking lot made it maybe a mile down the road and it began bogging down. the car seemed as if it didnt know weather or not it wanted to go or stop. i stoped in a parking lot then reved the engine a little bit to check for any symptoms i could and a large cloud of smoke came out the tail pipes. ?? drove it around for a few no problems then out of nowhere it did it again. i really need some quick help i have a road trip home this coming week and i need the car. so i would appreciate any help possible. thank you
every 3000 miles you should drain your oil, change the oil filter, and fill with 5w-30 synthetic, like shell rotella-T or Pennzoil Performance Platinum.... better yet just take it to the dealer....
do you have any check engine lights?
random insert
but, smoking as bad as the guy across the street from me? Just snapped this pic 30 minutes ago
thats some sea-foam..or atleast i hope so..this thread will be moved im sure but to the OP, seriously u added 2 quarts of oil..really?? did u check the dipstick first and see if u were even low..even if u were u only add a half a quart at a time and keep checking until its ideal, u just dont go throwing 2 quarts of oil into the car.. u should'nt own a car if u did that..period.. and to top it all off u put the wrong oil in the car, u should atleast be using 5w-30 or 5w-40 if ur having the smoking issue.. drain out the old oil..get a new filter and fill the car with 5 1/2 -- 6 quarts of the correct oil and call it a day.
first off i apologize for posting in the for sale section. and yes i checked the dipstick and it was low. all the cars ive owned in the past have been pos and when i needed to add oil i needed it in quarts. i now realize that adding that much was a bad idea. and no i didnt get any check engine light. and no im not taking it to the dealer im not that stupid. just a mistake is all. i changed the oil out completely with 5w-30 and i believe the issue has gone away. thanks everyone for the help
Moved to the correct section.
Welcome to the forums. First off, make sure you're putting at least 5w-30 (or 5w-40) in the motor at all times. Otherwise, smoking is inevitable. Car takes 6 qts. with a filter change too.
Add the pic as an attachment to your post.
From your avatar pic, it looks like a regular 6, not a speed (by the wheels).
it is and i didnt even think about the whole ms6 being a speed until after i seen some of the posts. does that have anything to do with 5w-20 vs 5w-30?
Yes, that makes a difference. Check your owners manual, you may have to use 5w-20. Hopefully another 6 owner can comment on that.
