blinker / running lights
BC3I
Contributor
2004 | Mazda 3i
hey does anyone know how to change the orange blinker plate on the headlights?? cause i wanna go with a cleaner look...thanks
i was just reading in another forum that you just pry it off when you open the headlights. The person that did it had the headlights open for the DDE installation so he just pryed it off carefully.
I have not done it myslef but thats what i read, i wll probably do it in about 2 weeks to a month
what forum was it do you know??? and i still can't figure out how to get those f-ing head lights out!!!
i cant remember i just got there following a bunch of links.
Its is quite simple to get your headliughts out. You habve to take the bumper out, unscfrew a couple of bolts, disconnect the bulbs and the pull out the housing. Then you use a heat gun (or you can bake them) and pry it open. once that is done you have access to the lenses and the reflector. If you ask me its not worth it unless youa re doing more than just removing the reflector. Im waiting till i get my DDEs.
