Okay, thanks! I've only had them set to "auto."
Related "beeping" question: is there any way to turn off the beeps when you lock or unlock the door? I sometimes come home late and would hate to possibly wake the neighbors. It seems to beep whether i use the fob, the door button, or even the inside lock. Changing the settings (or what I think are the settings) in the infotainment doesn't seem to do anything.
That's what I thought but when I did that it beeped.Just push the inside door lock button as you exit the car and you will only hear the lock actuators.
When I fiddled with that last week it didn't change anything. Eh, maybe I'm doing it wrong. Will try again - and if all else fails I'll read the manual.It's in settings under vehicle. Keyless volume. Just tested. Worked.
Nope, tried just using the inside door lock and it still beeped (though perhaps not as loud).
And I set the keyless volume to "off" and it still beeped when I locked the car via the door handle button.
Gonna read the manual more thoroughly tonight!![]()
Strange, if I lock the car using the inside door lock button and then close the door, no beep.
Are you guys talking about the electronic door lock button (inside) or the manual lock by the inside handle?
I figure there are four ways to lock/unlock the car:
1. keyless fob
2. button on outside handle
3. inside electric lock
4. inside manual lock
All except the manual lock (which I'm not sure about) will beep once or twice for me, no matter how it's set on the infotainment screen (which is currently set to "off")
Playing with this some more. I turned off the sound. Car does not beep when using the remote. Does not beep when using the outside door handle button. Does beep using the walk away feature. Is this the beep you're hearing RDK?
Sent from my LG V10
What is this feature? Anyone?
Sent from my LG V10
