mymmeryloss
- 13bT Mazda B2600i
Ive heard the same...
Lemme know what u find out...
Ballin! Glad im not the only one running aem on here!
I've had one running for two years.... Glad to help JT with the headache!
hopefully
No kidding. Ride to work was good. Idle only has issues when stopped. Freeway = not a lot of stopping. During lunch I'll be in some fairly heavy traffic and stop lights and get to see how things run. I'll wing by Advance to see what codes I throw today and get a better look at my CC vac lines in the sunlight
^ I have that same code!
which selonoid is the one we need?! from where can i get it?
That's what I did!Except I did it myself lol
me too minus the fancy machining that you did.
The plugs that go into them are white and green, but yes, they connect to the solenoidso if I have that code i just need to replace those colored sensors? until i do the same mod ur doing?
Lol fancy on a 30 year old mill. Sometimes the old machines just work better than the new ones
+1when it comes to machining i believe the older machines do a much better job and are more reliable then the newer stuff.
the blue is the actual solenoid?The plugs that go into them are white and green, but yes, they connect to the solenoid
*Shown below in the RED box*
