Bike Rack Options
'olzoomer
Any of you have bike racks (Yakima or Thule or other brand) on your PR5 tops? I'm looking to carry my Cannondale Lefty around. The rack has to be able to carry the full bike (without taking off the front wheel due to the Lefty fork).
Thanks!
'olzoom
"All I wanna do is zooma-zoom-zoom-zoom and a boom-boom..."
the yakima ankle bitter is probably going to be your only option with a bike like that unless you get a hitch mount rack..
I've got the <a href="http://www.thuleracks.com/thule/product.asp?dept_id=8&sku=599xt">Thule big mouth upright</a> for my MTB.
Here is a pic
<img src="http://www.protege5.com/members/azeli73/My%20First%20Set%20of%20Images/sleeping.jpg" border=0>
sorry that is the only pic i have with it on
Personally i run the thule big mouth upright as well...but you have to keep in mind that the down tube (on the cannondales which feature the lefty fork ) is too big for that rack..
azeli73,
thanks for the pic. Looks great on the PR5. Is it attached on the factory rack? Or did you have to buy the 400 Aero Foot Pack? I do not have the factory rack on mine. How much did it cost for the whole system? Any problems with noise with it on the roof?
AlexMack, Good point. The Big Mouth is advertised for upto 3-1/8" diameter downtube. Gotta measure the F800 then. I just checked the Yakima King Cobra (geez! cool names aren't they?) and that seems to work (fit) since it it grabs on the front wheel instead of the frame. But it seems to me that the Thule Big Mouth system is probably better on securing the bike. Do you guys agree?
Thanks for the info!
'olzoomer said:
azeli73,
it is attached to the factory rack. big mouth rack packs was $300 total to carry two MTB's. the mouth clamp will rattle if left on. other than that all i got was the usual noise heard from factory racks.
Has anyone here bought a carrier that will mount to the hatch. like the Yakima 'Joe'. Any reason to stay clear of these? My other idea is to get a hideaway hitch welded. is that possible?
If you want an upright system (both wheels stay) that attaches to your Factory Rack then the best option is the 899XT - Big Mouth Rack Pack .
This is THE best option for carrying your bike on the Factory Rack.
If you don't want an upright and don't mind taking the front wheel off then you can get the 889 - Velo Vise Fork Mount Rack Pack . BUT, if you set it up facing forward, like it's supposed to, you can't open your hatch all the way because it hits the rack. If you set it up backwards then it won't interfere with the hatch.
The upright rack isn't in the way of the hatch because it sits further forward on the factory rack. The only thing is that the clamps they have just barely fit on our racks, but it's doable. You can always get a longer screw :D
personnally after years of having yakima racks...i recommend a trailer hitch and a rear rack....about the same $$ , but easier to get off and on and less chance for damaage to your vehicle....and better aerodynamics.
7-8yrs ago o had a civic hatchback w/ 5!! bikes on top...and 1 time my ft wheel passed me on the frwy....lol
so you think those Yakima mighty joe racks will work on our P5's? I want to be able to carry two downhill rigs @ about 60+ pounds.
http://www.hollywoodracks.com/
Heres a detailed explanation about how I got my 589 fork mount trays on my 2003 MP5, so hopefully it should answer some questions about getting a rack on our cars. Points to note: If you use the Thule 889/899 kit with the spacer on the back instead of a load bar your tray will sit about a lower in the back and it looks kinda gay. It just undoes the the low front end, high rear end, muscular, aggressive look of the car. Also you wont be able to use a ski carrier because the back carrier wont have a Thule load bar to sit on, it would be lower in the back and all weird. The load bar included in the 889/899 pack is only 31 long . If you only need to carry one bike youll be okay but if you want to get two trays on the load bar youd have to mount them kinda inboard, so theyd be hard to reach if youre short like me. I bought the parts bags seperately for about $35 and used the Thule bars that I already had for my setup.
I already had a full Thule setup from my last car but the 400 feet were useless because the track that the factory crossbars run in is totally in the way of the feet and Thule doesnt make a Tracker kit that fits the tracks so I was forced to use the factory crossbars. The big problem was that the factory crossbars are way too far back on the roof so pretty much anything that you put on the roof is going to hit the spoiler when you open up up the hatch so theres one obstacle to conquer. The other big thing is the shape of the factory crossbars. The 589 will only mount to square Thule or round Yakima bars. The only option was to mount my Thule load bars to the factory crossbars and then cut the 589 trays short enough so that they wont hit the wing.
So heres what I did: I cut my Thule load bars down to about 40 so they dont stick out too far and I mounted them to the factory crossbars using Thule part # 853-5267 clamps and the associated parts. I did have to grind away part of the clamp to match the profile of the factory bars because the clamps werent quite large enough, or the screws werent quite long enough depending on how you want to look at it. The next part was to cut down the trays for spoiler clearance. If I cut the back of the tray I was going to have to machine out about five odd shaped holes where the plastic end cap snapped in and that was going to be a pain so I decided to detach the tray from the head and cut that end with a miter saw with a metal blade so I would only have to drill the one 5/16 hole for the single bolt that holds the head to the tray. Much easier. I think that I had to lop about 6 off of the tray. Once I got that reassembled the rest of the installation is as expected.
Heres a link to the Thule site where you can get the part numbers for the small parts that you may need. Any shop can order these.
http://www.thuleracks.com/thule/product_spare2.asp?dept_id=8&sku=889
Hey Mazda, please stop using a roof rack system alltogether. We all would prefer to use a regular system such as the Thule 400 feet. The rack would be much further forward on the vehicle so we could actually carry stuff and best of all we could run a fairing which looks pretty sweet
To answer the question if anyone has used a hatch mounted bike rack, I have the Rhode Gear Shuttle that I purchased for a previous car for trunk mount. I just changed the orientation of the lower bar on the unit and it now will mount very nicely to the hatch on an MP5. I will send pics when I head out to a SandBlaster race at the end of the month. I have removed my roof racks due to wind noise and favor the hatch mount now that I know it works... (2thumbs)
GNsPR5, That's great. If that solution works on the PR5, that's probably the (cheaper) way to go for me with my Lefty. Those pix should be very helpful. Thanks.
I'm most likey going to put my Thule rack on eBay (PM me if interested ;) ) soon and get a Yakima MightyJoe.
Anyone out there had a hitch welded??
O.K. I just went out and bought my new mountain bike for 2003. Someone asked about a carrier for the hatch. Well, here you go.(thumb)
2003 GIANT NRS2
Full-suspension ROCK SHOX SID rear
Shimano XT hubs and shifters
RaceFace Prodigy XC cranks
Avid AD 3 disc brakes
Sigma Sport Targa Bike computer
Let's get closer...mmmm
Rhode Gear Shuttle bike rack
Follows the roof lines
Hey! That thing DOES have disc brakes!!!!
Maybe we should go turbo on both...hmmmm
Brand new the Rhode gear Shuttle costs $175 but you can find them on e-bay for less. Thanks for the kudos on the MTB. It is a sweet ride!!!
