doclaw64 said:shift at 2k. Driving like that will get you better mileage but it will suck driving like that. You are in 5th at 40 mph. Very unfun.
2002yellowpro5 said:ok i dont get it i dont push the can and i only go 400km per tank and when i push it i get 380km per tank what the hell am i doig wrong guys i keep the revs between 2000 rpm and 3000 rpm (dunno)
(mswerd) I think 3k even to 4k is ok, the main thing is just hardly giving it any throttle(read "no fun"). Keeping the revs too low can actually be inefficient too since there is no power down there, and you are just throwing a bunch of fuel around when you stomp it and it goes nowhere. I wonder if it would be possible to quantify fuel efficiency for a car in a graph, based on throttle position and rpm maybe (would need to be a 3d graph I guess). You would probably have to calculate crap from fuel maps and dyno info or something. Then you could figure out some optimal driving habits, like what rpms are the best, etc. But then again, that would probably be information overkill.Mike R said:I tried that, the thing is the load increases on the engine, and it uses more gas. There is a very fine line for good MPG on this car.
FLSilverP5 said:Ive been filling up 14 gallons and up. Last week i filled up 15.15 gallons in a 14.5 gallon tank
ShakeThis said:One thing i have noticed and do not like is that the car rests at about 3900 rpm's at 79 mph...maybe it's just me but that seems way too high.
maxek said:. My other car that is V6 3.5L 250hp burn less gas than P5.
