Ok so I've been having a FEW problems as of recently..
I had my car parked in my driveway for a few months because I needed a trans.. Just swapped that out on the car and tried getting back on road with some failure..
Firstly, I had apparently tipped over the battery (which is located in the trunk) and it had leaked almost all if not all the acid out and into my trunk.. I replaced the battery with a BRAND NEW one and also clipped old terminal blocks off wires and put on new connections for new battery..
NOW, when I stripped back cable for new connector.. I noticed plenty of oxidation / decay buildup INSIDE the wrapping and ON the copper wire (using 00-welding cable for battery trunk-engine bay)
So the problem is while driving. The car is misfiring and sputtering and wont get past 3000 RPM.. wont even get near boost.. I am suspect of the coilpacks and coil wires. I pulled all 4 spark plugs and they look to be in pretty good condition, BUT I ALSO HAVE SOME OF THE OXIDATION BUILDUP INSIDE MY COIL / PLUG CHAMBERS?!@#!%$
what am I to do? put battery back in engine bay?!@#$ replace ALL wires?!@!$ wtf
I just want my car back!
help!
help!
