Battery cover
duplicate post deleted.
As for your question, its just a plastic cover. The only downside to having it off is that you would then have to look at the battery.
There is a cooling duct from the hood that matches up to the hole in the cover. It will be slightly less effective with the cover off.
Heat reduces the lifespan of a battery. Providing some airflow over a battery extends its lifespan. At least that was the whole point of the ducting for it.
