bad Noob!
Spoonfed
2003 MSP
i dont mean to waste a one post-answer thread, but being that the MSP is factory turbo...what is the stock Psi?... i remember reading it in a recent post but i cnat find it anywhere. also for my seocond Noob question, could you guys please explain to me, what reflashing the ECU is...as well as the difference between the welded LED as opposed to the stock LED? or even worse what the LED is.
oh man im such a noob to this car its soo bad.
sorry for the wasted thread i feel like an idiot.
I believe the stock psi differs from car to car between 6-7psi usually. Also, the reflash I believe helps with hesitation but all they do is advance the timing a bit so I dont think its a good idea to get if you plan on modding. I think you mean welded LSD, not LED. The LSD has a tendency to break apart at the seams so to speak, most members just take it out and weld the outside of the housing between each rivet. If someone has a picture they should post it. Hope this helps. Make sure you use the search function.
yeah bro, thanks...i did mean LSD i think i felt liek such a *ucktard askign those questions that i screwed up the spelling. thanks man.
